Home Forum Ask A Member Year of Mercury super " 5 "
  • #2091
    billy-j
      US Member - 2 Years
      Hello, just picked up a Mercury Model KF5 serial number 356434 for $60.00. Not all that familiar with the Merc’s. I would like to know the year of manufacture. Pretty nice shape has some broken fins on lower unit housing. Thanks Bill,
      #20758
      terriblecj
        1949 sir. Same year as mine. Great little motors!
        #20800
        billy-j
          US Member - 2 Years
          1949 I did not think it was that old. I thought about 1951 or 52. Thank you Bill,
          #20803
          dave-bernard
            the newer ones were called mark5’s had neutral shift.
            #20834
            20mercman
              The KF-5 was built from 49 -52. The Mark 5 was built 53-55
              Steve
              #20842
                US Member - 2 Years
                Your coolinng system is different than the later KF5’s The impeller housing should be upgraded to the later motors. Includes o ring housing & cover.
                See Fergoson Poole Marine & ask for Joe Poole. He knows all about it & has the new parts.
                #20857
                billy-j
                  US Member - 2 Years
                  Thanks all. I ran the Merc engine today. Had the test barrel setup for three other Johnson motors and thought I would give it a shot. It runs very well on gas oil mix shot into carburetor but will not run on it’s own I am sure the carb needs a thorough cleaning and going over. The lower unit housing has some of the fin broke off also the next part up ( the leg )? Would any of these parts be replaced with the impeller housing upgrade? Anybody have some of these parts? Also I ran it on 16 to 1 mix.Is this what it normally takes? Bill,
                  #20858
                    US Member - 2 Years
                    Your tank filter is clogged. Remove the tank & its on the bottom.
                    Send me your e mail & i’ll send a copy of the impeller change,
                    Jeff.50@cox.net.
