Home Forum Ask A Member Zephyr information
  • #2059
    r-delawter
      I acquired two zephyr motors at the Constantine meet that I would like to get running. models 4362 & 4404.
      Can someone direct me to a shop and parts manual for these? Also I will be needing a carburetor for the 4362 as part of the main body is broken. I would like for someone with a working knowledge of the zephyr motors allow me to use them for some guidance on this project.
      #20462
      justing
        I have a complete 4404 in my basement I have no plans to do anything with. Are the carbs the same on those? Let me know if your interested in my motor.
        #20464
        r-delawter
          I am just learning so I can’t answer the carb question.
          You can say here or message me info on your motor and where you are located. Thanks for responding.
          #20467
            I have some NOS non-primer carbs for Zephyrs still in their original box.
            #20472
            wedgie
              There is some info in Garry Spencer’s Drop box. I will pm the link after work tonight
              #20474
              r-delawter
                quote Mumbles:
                I will keep you in mind when I figure out what carburetor I will need. Or maybe you can tell me what I need for the models I have.
                #20475
                r-delawter
                  quote Wedgie:
                  Thank you.
                  #20504
                  joecb
                    US Member - 2 Years
                    Mumbles, what is a zephyr "non- primer" carb? I have a couple of Zephyrs and they both have the primer, I thought that all of them did.
                    #20512
                      What I should have said was ‘non primer button’. Yeah, they all have primers but they are activated differently. Early ones used the mixture knob to prime the motor while later ones had a push button primer on the front cover. My bad.
                      1940 Zephyr
                      1948 Zephyr
                      #20514
                      r-delawter
                        By golly, with everyone’s help, I am a learning. Thanks for the information on carburetors.
