Home › Forum › Ask A Member › Zhongfadz coil
- This topic has 7 replies, 3 voices, and was last updated 1 year, 6 months ago by seakaye12.
April 1, 2018 at 10:00 pm #9534
I got these out to use today and found them glued to the laminates. No problem just cut the glue. They seem a little thick to use on my Elgin laminates. Is it okay to file the rivet down flush and maybe remove the top laminate where it make a T? if you know what I mean.
April 1, 2018 at 11:02 pm #73331Whatever it takes.
April 2, 2018 at 2:04 pm #73352April 3, 2018 at 2:25 am #73386Glad to hear those Chinese coils come off the laminates.
I was going to use one on my 2 hp Westbend, but wasn’t
sure how well they were glued on, and not wanting to
ruin the coil, opted for an OMC coil.Prepare to be boarded!
April 3, 2018 at 2:48 am #73388I think the tab should be removed. The back of one cracked and about a 1/4 of it fell off. I put it back on with some Corona dope. Ñot sure if that happened during removal or installation of coil on laminates.
July 29, 2023 at 8:42 am #278630So where are you buying these coils from?
I would also ask how do you order the correct coil?
I understand we reference the laminate core size, however does this yield the correct coil every time?
I would like to know the part number that correctly cross references with the motor.
So many concerns over ordering the correct coil replacement. The cost of the Zhongfadz replacement coil (direct) is very low.
so how can I be certain I’m ordering correctly?
Martin 40 engine, needs 2 coils.
July 29, 2023 at 9:08 am #278632they have several numbers but… pretty much all the same cheap on amazon …. check prices with or without shipping …some on ebay to !
July 29, 2023 at 9:08 am #278633They are using the OMC style coil. Many many people on ebay and Amazon are selling them. Here’s one:
If you look close at his pics you can see the brand name on the black plastic
